It is currently Thu Aug 14, 2025 10:29 pm
PostPosted: Thu Nov 03, 2016 11:18 am
Tempted by this.
A small shooting board's been working OK, but a bit time consuming and fiddly.
Anyone using this item?
These users thanked the author Colin North for the post: Joe Beaver (Thu Nov 03, 2016 5:20 pm)
PostPosted: Thu Nov 03, 2016 11:20 am
Not in my estimation.
PostPosted: Thu Nov 03, 2016 12:38 pm
Haven't felt the need.
PostPosted: Thu Nov 03, 2016 1:49 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
It is darn expensive. If it cost $50 or less, I might be tempted. At a cost of more than 3X that much, I can live without it.
PostPosted: Thu Nov 03, 2016 2:02 pm
Make a little holder out of wood, that captures the nut or saddle. Fit it with a little wooden handle on top. Makes it much easier to sand the stuff. You'll probably need a few of these although they don't take long to make. You can also scrape bone pretty well
PostPosted: Thu Nov 03, 2016 2:44 pm
$94 from Canada
PostPosted: Thu Nov 03, 2016 2:51 pm
I found a small 90 degree shooting board with a block plane blade honed at 10 degrees back bevel works fine for bone, and anything else I've done so far.
PostPosted: Thu Nov 03, 2016 3:04 pm
We do bone blank sizing using our 10-20 drum sander -- multiple blanks are hot glued to a piece of Masonite (no reason not to do one at time). Release the glue with alcohol. I've become pretty good at shaping bone using a 1x30 belt sander.
As for buying the gadget -- no way. $15 maybe
Ken Cierp
These users thanked the author kencierp for the post: askins (Thu Nov 03, 2016 6:21 pm)
PostPosted: Thu Nov 03, 2016 3:54 pm
Last Name: Beaver
City: Lake Forest
I have never seen one of these. Who sells it?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Nov 03, 2016 4:15 pm
SM sell these, as do http://heart-sound.com/en/products/nut-and-saddle-sander/
Least expensive I found is here http://www.guitarbuilderonline.com/luthier-tools.html
What attracts me is the quick and accurate removal of different amounts from the two sides of a saddle as I've had a fair amount of set-ups over the past couple of months.
PostPosted: Thu Nov 03, 2016 5:05 pm
I have one, the stewmac version. I like it
A friend bought one and was enthusiastic so it bought it.
You do not use it for blank sizing, it is aimed at allowing you to adjust action height quickly and accurately without relying on working to marks, and with my aging eyes that is a good thing.
Say you have a guitar where the action is 2.5 and 2.2 mm and you want it at 2.3 to 1.6.
Fit it in the jig level then dial in the adjustment at each end, clamp and then sand till it rides on the wheels.
Done
If it saves you from having to detune, try, retune etc or having to make up another blank if you overshoot then I think it is worth it.
These users thanked the author Jeff Highland for the post: Joe Beaver (Thu Nov 03, 2016 5:19 pm)
PostPosted: Thu Nov 03, 2016 5:19 pm
Last Name: Beaver
City: Lake Forest
Thanks Colin, I'll check it out. I do like what Jeff is saying. Sounds very useful.
Might be a good item for my Christmas list.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Nov 03, 2016 8:50 pm
Accurately marking bone has been tricky for me because pencil lines tend to smear. If this can really be had for $93 rather than $180 from Stew-Mac, and if it really makes precise heights easy to dial in, I think it would be worth it.
PostPosted: Fri Nov 04, 2016 4:36 am
That would slow me down, I make nuts and saddles every day. Free hand or a block handle with duct tape attaching the nut/saddle blank, an eye on safety, next. Part of how I work with my nuts.... and saddles is to use my caliper frequently as I approach the machine thickness that I want. Wondering if this thing exposes enough of the blank to even get the caliper on it.
This one might go down in Stew Mac history as giving the previous most useless tool, the toothing file.... a run for it's money.
Pass.
PostPosted: Fri Nov 04, 2016 5:41 am
I've made a few holder thingamabobs from plywood, bolts and wingnuts to hold nuts and saddles, which I shape on my belt sander. They are great for saving you knuckles, and best of all, cheap (just like me). Accuracy and speed comes with practice.
PostPosted: Fri Nov 04, 2016 7:55 am
I've also got a home grown "Luthier's Friend" and "Small Parts Vise " so preparing/shaping and squaring nuts and saddles is no problem.
But 120 grit doesn't cut it in my book for the bottom of a nut or saddle, (especially with a UST)
Yes, Arnt, I've learnt my lesson with the belt sander too, got the scars to remind me..
PostPosted: Fri Nov 04, 2016 8:16 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I agree with Hesh. I make and adjust nuts and saddles daily. I can lower a saddle by marking a fine line with a mechanical pencil with sharpened lead (I keep a little piece of 320 grit stuck to the corner of my bench for lead sharpening), sanding to the line on a disc sander, and then honing the bottom flat on a slab of granite with 320 gold on it, in less than 3 minutes. I looked at this tool when SM introduced it, and quickly decided to pass.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: Hesh (Fri Nov 04, 2016 12:42 pm)
PostPosted: Fri Nov 04, 2016 9:16 am
That is exactly the way I do it too.
Some time ago I received a Luthier's Friend as a Christmas present; I don't use it for too many things but it does a great job of doing the initial thicknessing for nuts/saddles. Last step is on the 320 gold/granite. I was able to thickness a saddle on Dave Collins' belt sander but when I tried it on mine I just sanded my fingertips so the Luthier's Friend will work for me.
Also, I notice StewMac touts that their tool lets you keep the nuts/saddles square. If you have trouble with that by hand you can always put them up against a square block of wood while you sand the edge. That will keep it square. I do that all the time when I sand braces in a radius dish.
These users thanked the author SteveSmith for the post: Hesh (Fri Nov 04, 2016 12:42 pm)
PostPosted: Fri Nov 04, 2016 9:59 am
Last Name: Farmer
City: Durango
State: CO
That's how I do it too too.
The start of any set up work includes checking the saddle for flatness and nut slots for shape.
I used to actually check with a straight edge and fix if necessary. Now checking is fixing. I swipe the saddle bottom with a pencil and put it up against the disc sander and rotate the disc a fraction of a turn by hand. Scratches show and fix in one operation. Same with nut slots.
Pencil drawn in the slot bottoms, one very light pass with a file, and it shows whats going on with string contact. All subsequent issues and estimates are dependent on the two string endpoints, so starting the fix is just part of the evaluation. It's faster than even taking the time to talk to a customer about it so i usually just do it. Even If they decide not to have work done.
I guess its a little door prize.
These users thanked the author david farmer for the post: Hesh (Fri Nov 04, 2016 12:43 pm)
PostPosted: Fri Nov 04, 2016 11:45 am
Now c'mon guys! Luthiers are supposed to LOVE jigs and fixtures. Where's the love!
It might be a cool little tool for $5 or $10, and that's about all you could sell it for at a flea market. In a couple of months you might find a Chinese knock off on eBay.
These users thanked the author Clay S. for the post: Hesh (Fri Nov 04, 2016 12:43 pm)
PostPosted: Fri Nov 04, 2016 12:27 pm
Steve, just curious, but is your Luthier's Friend permanently set up? If not, how long does it take to set up? If it's set up all the time, or doesn't take long to set up, it seems like a great option because it will work both planes of the nut or saddle (thickness and height), where this little tool only seems to do height.
I just looked at it for the first time. I've been envisioning something similar in my mind for flattening the backs of headstocks on my Ridgid belt/spindle sander, only my version would be larger out of necessity.
PostPosted: Fri Nov 04, 2016 12:39 pm
James, it's temporary but it only takes a few minutes to set up, not much more than putting a new drill bit into the chuck. I chuck the sanding drum in the drill press and use two quick clamps to hold the base on my drill press table.
I made an adjustable table for the end of my 6x36 belt sander that I use to flatten the backs of headstocks.
PostPosted: Fri Nov 04, 2016 1:18 pm
Thanks, Steve.
That's exactly what I'm trying to recreate. I don't have the belt sander, so I'm trying to create the same tool in effect to use with the spindle.
PostPosted: Fri Nov 04, 2016 2:36 pm
Last Name: Beaver
City: Lake Forest
Perhaps somewhat off topic but...
I too used my belt sander to thickness headstock. I never made the jig. I would mark final thickness on the sides of the head then sand by eye.
I have recently resurrected my 30 year old Safe-T-planer and have been using it. It is more accurate and easier than the sander routine.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: James Orr (Fri Nov 04, 2016 9:09 pm)
PostPosted: Fri Nov 04, 2016 3:28 pm
Pass.
It's not really used for the initial making of the nut or saddle at all. I do that on my disc sander.
Where it is used is on an existing saddle or after the initial stringup with a new saddle which you have left high. Measure the string height at the 12th, work out how much you need to take off, dial in the appropriate notch on the thumbscrews and sand.
No, calipers will not fit, you don't need them, it stops when you get to the required height.
These users thanked the author Jeff Highland for the post: Hesh (Fri Nov 04, 2016 3:49 pm)
Users browsing this forum: Dmaxwell, pkdz and 19 guests
